CoordinateSystem / Macro / VisualBasic / SW / MassProperties
hey!
i have written a macro to get the mass properties of the different parts of a solidworks assembly on an excel sheet. the problem i have is that i get all this properties according to the default coordinate system.
i have checked the API help but i am a beginner in this field and i can't find a solution.
i show you the macro i was using (only for the part LowerArm-1) so if you know what should i add to my macro, please let me know it!
Sub massdata()
Dim swApp As Object
Dim swModel As Object
Dim swDocExt As Object
Dim swMass As Object
Dim swSelMgr As Object
Dim swComp As Object
Dim vBodyArr As Variant
Dim vCoM As Variant
Dim vMoI As Variant
Dim vPrinAoIx As Variant
Dim vPrinAoIy As Variant
Dim vPrinAoIz As Variant
Dim vPrinMoI As Variant
Dim nDensity As Double
Dim bRet As Boolean
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = CreateObject("SldWorks.Application")
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("LowerArm-1@Assem4", "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
Set swModel = swApp.ActiveDoc
Set swDocExt = swModel.Extension
Set swMass = swDocExt.CreateMassProperty
Set swSelMgr = swModel.SelectionManager
Set swComp = swSelMgr.GetSelectedObjectsComponent2(1)
vBodyArr = swComp.GetBodies2(swSolidBody): Debug.Assert Not IsEmpty(vBodyArr)
bRet = swMass.AddBodies((vBodyArr)): Debug.Assert bRet
vCoM = swMass.CenterOfMass
vMoI = swMass.GetMomentOfInertia(swMassPropertyMomentAboutCenterOfMass)
vPrinAoIx = swMass.PrincipleAxesOfInertia(0)
vPrinAoIy = swMass.PrincipleAxesOfInertia(1)
vPrinAoIz = swMass.PrincipleAxesOfInertia(2)
vPrinMoI = swMass.PrincipleMomentsOfInertia
Debug.Print "File = " & swModel.GetPathName
Debug.Print " Comp = " & swComp.Name2
Debug.Print " Config = " & swComp.ReferencedConfiguration
Debug.Print " Density = " & swMass.Density & " kg/m^3"
Debug.Print ""
Debug.Print " CenterOfMass = (" & vCoM(0) * 1000# & ", " & vCoM(1) * 1000# & ", " & vCoM(2) * 1000# & ") mm"
Debug.Print " Volume = " & swMass.volume * 1000000000# & " mm^3"
Debug.Print " Area = " & swMass.SurfaceArea * 1000000# & " mm^2"
Debug.Print " Mass = " & swMass.Mass & " kg"
Debug.Print ""
Debug.Print " Ix = (" & vPrinAoIx(0) & ", " & vPrinAoIx(1) & ", " & vPrinAoIx(2) & ")"
Debug.Print " Iy = (" & vPrinAoIy(0) & ", " & vPrinAoIy(1) & ", " & vPrinAoIy(2) & ")"
Debug.Print " Iz = (" & vPrinAoIz(0) & ", " & vPrinAoIz(1) & ", " & vPrinAoIz(2) & ")"
Debug.Print ""
Debug.Print " Px = " & vPrinMoI(0) & " kg*m^2"
Debug.Print " Py = " & vPrinMoI(1) & " kg*m^2"
Debug.Print " Pz = " & vPrinMoI(2) & " kg*m^2"
Debug.Print ""
Debug.Print " Lxx = " & vMoI(0) & " kg*m^2"
Debug.Print " Lxy = " & vMoI(1) & " kg*m^2"
Debug.Print " Lxz = " & vMoI(2) & " kg*m^2"
Debug.Print " Lyx = " & vMoI(3) & " kg*m^2"
Debug.Print " Lyy = " & vMoI(4) & " kg*m^2"
Debug.Print " Lyz = " & vMoI(5) & " kg*m^2"
Debug.Print " Lzx = " & vMoI(6) & " kg*m^2"
Debug.Print " Lzy = " & vMoI(7) & " kg*m^2"
Debug.Print " Lzz = " & vMoI(8) & " kg*m^2"
End Sub
Sub massdata()
Dim swApp As Object
Dim vCoM As Variant
Dim vMoI As Variant
Dim bRet As Boolean
Dim Part As Object
Debug.Print ""
Debug.Print ""
Debug.Print ""
Debug.Print ""
End Sub
RE: CoordinateSystem / Macro / VisualBasic / SW / MassProperties
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
i do:
insert > reference geometry > coordinate system
then i want to get the mass properties according to this coordinate systems.
in the API help i have found MassProperty.SetCoordinateSystem but i don't know what i have to write on visual basic to use it
