valve database program selection
Hi all,
i want to ask about valve database system. What is the best software or application to maintain valve database in a plant twhich is about 20.000 valves present.
i had search about valvkeep and total valve management, some other input said Excel with macro or Access customized with our plant.
the constrain is about budget.
do you have some experience in your field/plant
appreciated your input
RE: valve database program selection
are you interested in managing valves only?
How about pumps, pipes, instruments and all other pieces of equipment in your plant?
Maybe you can join forces with your Colleagues and... join budgets too, so you can get a more comprehensive software
Moreover, does your Company run an ERP System? If so, maybe this System can offer modules dedicated to equipment registry and maintenance, plant shut-offs management and statistics.
For example, I once worked with PM (Plant Maintenance) and PS (Project System) modules of SAP R/3 software (see http://www.sap.com/about/company/history/index.epx) and they seemed quite good; but, of course, the Company run other SAP modules, basically FI-CO (Finance & Controlling) which was the core of the installation, and also MM to manage warehouses and purchasing process, as well as IM to manage the budget elements' structure (see http:/
Good Luck!!! 'NGL
currently, i only focus in valve.
my company using different version of ERP to manage finance and operation. Asset management system which is used focus on planing and scheduling and asset maintenance, but not go detail on valve.
Heather's focus: Alloy Valves Duplex Valves Super Duplex Valves Monel Valves Inconel Valves Titanium Valves & 6 Moly Valves
