House Fire - Rebuild vs Remodel
My Florida wood frame house was burned pretty bad.  Fireman did a good job, but in my opinion the flooring and foundation are the only things worth saving.  How much of an existing structure must be saved to consider it a remodel as opposed to just starting over with rebuild?  It seems there are many advantages to go with the remodel avenue.  Thanks very much.
NeedToKnow
RE: House Fire - Rebuild vs Remodel
Here are some things to consider:
1.  The number one consideration is, is what is left after the fire structurally sound?  If it is OK, if it isn't replace it.
2.  Anything that is reused after a fire has a "fire smell" and MUST have a sealer applied to cut off the smell and allow new finishes to be installed.
3.  The real question as to rebuilding or remodeling what is left after a fire has to be negotiated with your insurance carrier and sometimes with you city building department.  Many times there are insurance provisions, building code or zoning ordinances that define what % of the structure can be damaged before it is classified as a "total loss" and must be torn down.
Good luck with a bad situation!
