Converting nut torque to bolt shank tension
How do I go about converting the torque applied to a nut into a tensile reaction in a fixed bolt. For example what tensile load will be applied to an expansion anchor fixed into concrete if a given torque is specified to adequately fix the anchor.
Thanks in advance
RE: Converting nut torque to bolt shank tension
Pull up the Hilti site--- www.hilti.com  or call (800) 679-7000.  Their tech people are ready to help with any related questions.  Their the experts and their advice is free.  Also available in several countries via the web site.
Rod
