NX6 extract face and sheet body transparent one direction
I have situation where extracted faces and sheet bodies appear without solid color from view plane likely opposite the surface normal.
Being new user with UG, is this a regular user setting or is there a setting I need to set. It only seems to affect features with a zero thickness.
See attached images.
I'm a new user, please be patient.
RE: NX6 extract face and sheet body transparent one direction
If this doesn't do the trick, try Preferences -> Visualization -> Visual and turn on the option called 'Two-Sided light'.
