help with outline
help with outline
help with outline
how can I do a paramtric silhouette outline in nx6?
thx in ad
RE: help with outline
By 'parametric' I assume that you mean Associative, correct?
If so, have you looked at...
Insert -> Curves from Bodies -> Extract -> Isocline Curves
...setting the 'Vector' to 'View Direction' and the 'Angle' to ZERO degrees (be sure that you are not in a Perspective View)?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
In drafting expand the view first.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
ok I thought of parametric,
Insert -> Curves from Bodies -> Extract -> ....
those curves are still without any associativity.
I thought there is something like plane from view,
or a workaround to get an associative result.
thx in ad
thx JOHN I found it...
