Half sphere spinning approx 30" radius
Does anyone know who has a tooling for this?
The material would be like 14 Ga CRS or thicker.
Your help is really appreciated.
RE: Half sphere spinning approx 30" radius
I would contact some of the larger metal spinning companies and if that not productive I would contact some of the vessel head manufactures that make hemispherical heads.
At your diameter a thicker diameter would probably be better if you can use same.
