NX5-6 PostProcess Problem
first of all sorry for my english I know its not the best lol
I have a question regarding NX post processing, i already have my drawings, assemblies, and program ready, tool path seems ok but when I get the output G code all the G1´s are G0 so when I simulate the code, all the moves are collisions
do you have an idea of what am i doing wrong??
thanks in advance
RE: NX5-6 PostProcess Problem
has some configurations in posprocessadores that depending on the advancement of cutting it throws him to invest in G0 G1 you can also try placing the advancement engage and retract in feedrate
what type of machine you want to process command and anything I can see you and the post processor has algun problem and so I have
Andre...
specialist and multi axis
development of IS & V
and postprocessors
member committee nxcam plm world
Check that the Cut feedrate has been set in all of your operations.
Mark Rief
Product Manager
Siemens PLM
If the feedrate is set and it is higher than the maximum in the postprocessor (postbuilder) it will also output rapids instead of linear moves.
I have the cut feedrate set for all my operations the maximum feedrate that  I use is 700 do you think that's the problem ??
LMK and thanks in advance
depends if it is metric or imperial units. You can check in the postprocessor tcl file and search for 'set mom_kin_rapid_feed_rate'. You can open the tcl file in an editor e.g. notepad or wordpad.
Have you opened the post in Post Builder?
Mark Rief
Product Manager
Siemens PLM
sorry I was having trouble logging
but you can send the file and post processor for me to analyze
hug
André
and postprocessors
