Suspension modell - bellcrank
presently I am trying to simulate a cfrp monocoque and to my shell-model I also want to include the whole suspension – and my main problem is the idealization of the bellcrank!
I have modelled the control arms via 1d-CROD elements, connected via RBE2 elements to the shell model of the monocoque – and the wheel support is also made of RBE2s.
But as I said – my problem is the bellcrank. Currently it is a CROD-triangle with connected CROD-pull-rod and CELAS1-spring. With this model basically it works – but the problem is, that it has no defined rotational axis and therefore the whole bellcrank (better CROD-triangle) deforms uncontrolled and not planar, like it should (just rotation around the rocker).
Perhaps, someone knows a proper solution for my problem??
And also a question to the CROD elems: I have defined CROD-properties with a large Young's Modulus to get "almost" stiff elements – but it is defnintly not the most elegant way! I also tried RRODs...but I just got errors...and no solution!
Best Regards
Michael Sams
RE: Suspension modell - bellcrank
Hey guys,
really no one - who knows a solution for my problem??
Best Regards
Michael Sams
I've never met anybody who uses MotionSolve for mechanisms analysis. Altair occasionally sound a bit hurt when I report my experiences with their software, so I guess now is the time to contact customer support.
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
