RBE2 Rigids
RBE2 Rigids
RBE2 Rigids
I've tied two structures together with rigids links. Is there a way to read the link forces in the output?
RE: RBE2 Rigids
gridpoint force balance ?
RE: RBE2 Rigids
Dear Bdidle,
In "Nastran Output Request" make sure to activate "Force Balance" (please note is OFF by default). Run your analysis. Go to F5, activate DEFORM & CONTOUR, click on DEFORM & CONTOUR DATA, select the Output set, the Output vectors & contour you like, and click on FREE BODY DISPLAY, here is where you are allowed to plot everything like reaction loads, multipoint reaction loads, etc.. You will need to create a group with the nodes where you want all that stuff data -- good luck!!.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
