library tools
library tools
library tools
How I can copy the library  tools from NX6 to NX7?
RE: library tools
replace the resource files mach libray tool_database of tools for nx6 NX7
I suggest you keep a backup of this file in case something wrong.
but I did so and it worked.
andré
specialist and multi axis
development of IS & V
and postprocessors
member committee nxcam plm world
RE: library tools
Hello aer73,
You can copy library tools as .prt template or
the .dat document form NX6 to NX7.
Can you specify, what you want please?
Thanks.
RE: library tools
all configurations of the tool is in tool_database. dat
Just copy and paste
André
and postprocessors
RE: library tools
Hi andre,
You can create an independent template from, too_database.dat.
A single .prt file with all tools you need and use it as a
template, not linked with the other database.
Thanks.
RE: library tools
yes it is possible '
create a new file and create all the tools you use in a folder and save your
then when you are creating a new machining you there to file> import> part> Select the Import path objects and selects the template with all the tools
created the file. prt then you go on view navigator tool in operation and the tools will be there
I am sending you a sample video
how to create and then import
and postprocessors
RE: library tools
Thanks to all.
RE: library tools
yes it is possible
first create the file prt with the tools you use
then create a new file go to file> import> part> select the option import cam objects set the point constructor 0,0,0, and go to the tool view the tools will be there as you created the file. prt
andre
and postprocessors
RE: library tools
If you have not added or changed any classifications or parameters, then you can use the same tool_database.dat. Occasionally, we require that the tool database files be converted (Tools --> Convert Tool Database), but there were no format changes between 6 and 7.
As a general practice for ALL of the CAM resource files, I recomment you merge (or at least compare) your changes in to the newest files, because we add new tools and make corrections to the existing tools. If you just copy your old files, you will miss the enhancements in the new release.
Mark Rief
Product Manager
Siemens PLM
