descon brace
descon brace
hello all,
does any one have experience using descon brace software for braced frame connections?
if so, what feedback would you give, and have you ever checked results with hand calcs?
TIA
TIA
RE: descon brace
http://www.FerrellEngineering.com
RE: descon brace
As an estimating tool, the software can provide valuable information for an accurate bid. Fabricators due not have the resources to design connections for a project at the bid stage. The software call allow an estimator to provide a more educated judgement of the connections required. However, conservative connection design will cost money in detailing, fabrication, and erection. And in turn cost the owner money.
Also, a good tool in the wrong hands can be dangerous. Without understanding the design principals a user can make gross errors. I have seen examples of moment frames designed with moments input as gravity moments only. Therefore not checking the columns for the appropriate column shear (additive lateral moment) or providing the adequate reinforcement. In this case the software was not conservative enough. But not due to programming error, but rather user error.
As I mentioned, fabrication and erection economies are rarely taught in the classroom or a lecture series. Therefore packaged software rarely make these considerations in their design. In my opinion the software users should understand the calculations being performed. Our proprietary software has been developed for nearly every structural connection imaginable. But, I require that all new engineers complete the same calculations by hand. They need to understand how changes in the detail effect the design limit states. What are the effects of changing bolt gage, pitch, edge distance, etc. etc. For most engineers their connection design experience consisted of 2 weeks during their steel course. Probably LRFD only and the textbook or printed examples are at least one manual edition behind. I recall one of my homework problems actually used rivets. Showing that even the professor lacked practical experience. Most young engineers don't even know that fabrication shop drawings are required and that all of the connections are detailed for each fabricated piece.
Sorry for my "soap box".
RE: descon brace
Go for it!
RE: descon brace
RE: descon brace
John Southard, M.S., P.E.
http://www.pdhlibrary.com
RE: descon brace
RE: descon brace
Are you using Ram Connection as a stand-alone product or with STAAD or Ram programs or both stand-alone and integrated?
RE: descon brace
