Babbitt pedestal bearing maintenance
What is the proper way to maintain and measure these types of bearings? We have an 8" and a 10" bearing supporting a 9 ton rotor turning at 180 rpm. The bearings are split with two oil rings for lubrication. Average clearance is about .045" measured in 3 places on each bearing. The journals show signs of wear, with the larger bearing having definite wear from the oil rings, and the smaller showing signs of pitting and waviness. I believe the 8" journal suffered severe damage years ago, and was built up and turned back down. I have no documentation stating acceptable clearances, but .040 seems a little loose. We are experiencing vibration by the motor, but I am unsure if it's coming from the motor. We only measure the oil temp, and it average about 120F. These bearings have been in service for probably 20yrs since they were last re babbitted, and I don't think anyone here has the experience to say whether they are fine, or should be addressed. I'd like a specialist to come out next year, but I'd like to educate myself first.
RE: Babbitt pedestal bearing maintenance
So 1/1000 of 203mm is 0.203mm. So your measured clearance of 1.01mm is somewhat slack. (Sorry, I don't understand imperial units, hence conversion).
