Filter graphics not working
When I type a string in the filter, only feature manager tree gets filtered showing only items meeting the string criteria.
But the graphic shows all the parts. I want it to filter too.
~ BT
RE: Filter graphics not working
Once you have the filtered parts listed in the FM, Shift select them and then;
1) If in a part, the features should become highlighted in the graphics area.
2) If in an assy, the parts will highlight and you could use the Isolate function to hide the non-selected parts.
Blu -
In the bar at the top of the FM, there's a little black down-pointing triangle just to the right of the filter icon. If you click that, you should get a drop-down box that lets you check or un-check "Filter Graphics View"
Steve R.
