Active Power Factor Correction
How to correct the power factor of a 3 phase AC Induction motor without using Capacitors?Control Algorithm or the design flow??
I just want to implement active power factor correction?
RE: Active Power Factor Correction
Furthermore at least in the low and medium power area nearly all motors are a standard design where also these features are governed by IEC or NEMA specs.
To recive more detailed answers it would be nice if you can specify your question more in detail:
power, application, reason for beeing so keen on power factor
The fact that you mention flow baffles me. How could you hope to adjust power factor by changing flow?
Perhaps you can give a broader picture of what you are trying to achieve.
The only way is either with an active power factor correction box or with an active front end VFD. I hope you have a large motor because either is expensive.
