Protected Mathcad sheets
Does anyone know if it is possible modifiy the format of a results on a protected mathcad sheet?
The sheet I am using is protected and I need to increase the number of decimal places of a result.
RE: Protected Mathcad sheets
Depending upon the level of protection, you may be able to add a new (duplicate) output of the result you're interested in & modify the decimal places on that.
Good luck
If you dont know the password, try opening the file in a text editor and look for the password, its normally pretty easy to find.
