Teamcenter Integration for I-deas jvm.dll Error
Hey all,
I'm stuck. GTAC is working hard, but not coming through in this case. Running WinXP 64BIT SP2.
I'm trying to IMPORT FROM TDM using Teamcenter Integration for I-deas (TCII), Teamcenter and I-deas 5m3. I'm getting the below error message
(tcserver.exe - Unable To Locate Component)
This application has failed to start because jvm.dll was not found. Re-installing the application may fix this problem.
I have installed Java(TM) 6 Update 20 (64-bit) AND Java SE Development Kit 6 Update 20 (64-bit)
My JAVA_HOME System Environment Variable is set to the correct path. C:\Program Files\Java\jdk1.6.0_20\jre\bin
Gonna head over to the GTAC forums now. Thanks everyone.
RE: Teamcenter Integration for I-deas jvm.dll Error
I'm extremly frustrated. I've never seen a piece of software THIS difficult to install.
What exactly is my company paying for?
GTAC was able to assist my Teamcenter guy with this error. No word as to how they fixed it though.
Problem solved.
