Help with material data
I'm doing a schoolproject where I'm trying to replace a steel construction with a plastic one.
Unfortunatly we don't have any teachers who is very good at Abaqus, and I find it way too hard to understand everything on my own.
I now need to place the material on my construction and all information I have on the material is attached in a datasheet (ht tp://www.e msgrivory. com/mytool s/datenbla etter/date nblaetter/ grivory_gv /GVX7H_nat ural_E.pdf).
Is it possible to "make" this material in abaqus? or can I find it in a material database perhaps? Appreciate all help!
RE: Help with material data
Yes should not be a problem, but you need to consider what you are trying to model (e.g. stresses), are you looking at a simplistic model (e.g. linear or non-linear)? If your not too experienced using abaqus have you considered using the analysis packages in piece of CAD software?
Hope that helps
- Model
- Materials
Hoping to say Tata
Remember to use the manuals and tutorials extensively because they are truly top notch.
I have always taken the policy on school work to be homework problems or lab reports. Not Graduate research or work for companies. In the future just don't say the word school.
Welcome to the wonderful world of FEA and Abaqus!
I hope this helps.
Rob Stupplebeen
yes it can. check elfini structural solver or sth like that in the license manager or whatever it is.
