Ball mill design - Input / resources sought
Hi
I'm currently designing a barrel for a lab sized ball mill to incorporate into a processing system. I've struggled to find any resources with specific design information so have cobbled together a calc sheet in excel to start the process off. I'd be really keen to hear feedback from anyone who may have experience in this area or who could recommend a good design resource. I've attached my spreadsheet, feel free to have a look and or use it for your own work.
So far I have been using Crushing and Grinding by G.C. Lowrison and Ball and Tube and rod mills by H.E. Rose.
Specs:
The mill is to be used to mush a 3 Liter 50/50 mixture of soil and water. Basically I'm aiming to homogenize the solution and reduce average particle size to around 1 micron. I want to run it as a batch process and am currently trying to optimize drum size, ball size and rpm.
Any assistance or nudges in the right direction would be greatly appreciated.
Cheers
Sam Davies
Specs:
Cheers
Sam Davies
RE: Ball mill design - Input / resources sought
rmw
The energy requiremetns to grind that fine are going to be very high- 1 micron is clay sized.
As a chem eng/metallurgist the first part of any answer I give starts with "It Depends"
