Clearance analysis and Reuse Library
I've an assembly and I used ISO standard threaded holes in parts and bolts of Reuse Library in the ISO standard.
The screw value is correc, for example with a M5 hole I put a M5 screw.
When I start the clearance Analysis me interfering signals.
The interference is due to the threaded hole has a pre-drilled smaller than the diameter of the screw.
There is an option that I exclude from the analysis of these situations?
Thank you
Thank you
RE: Clearance analysis and Reuse Library
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thanks again
John R. Baker, P.E.
Industry Sector
Cypress, CA
