How to publish dimension inside sketch
I know how to publish dimensions inside a surface feature (e.g. extrude lim) but how can i publish one inside a sketch?
I want to do this so it makes dimensions inside a sketch easily accesible without going through dozens of tree levels to reach it.
Rob
Rob
RE: How to publish dimension inside sketch
Turn on Tools - Options - Infrastructure - Part Infra -- Display -- Parameters of features and constraints.
Right click over the sketch constraint -- Add Display
You can add name and value, change the property page for this.
You will need to hide the parent to hide the dimensions. I place all sketches in a geo set called Inputs.
Derek
