motion study vs Explode-Render-Animate
I'm using Solid Edge v20, producing a series of animations. I can produce the movements I want in Motion study avi's (via displacement, not motors), however they lack the rendering and camera angle options you see in the Explode-Render-Animate tool.
Is there a way import Motion studies (not motors) into the ERA tool?
Or are there any add-ons or updated versions of Solid Edge which allow the combination?
RE: motion study vs Explode-Render-Animate
The motion environment is pretty old and has not been touched for a long while. Its also based on third party technology.
The only way to get parts to move in ERA is to use motors, exploded views or the motion path command. If you are stuck with just Solid Edge then I would suggest the best way is to use ERA.
Alternatively a few people on here have been using the Bumkspeed Move application with some great results.
http://www.bunkspeed.com/move/index.html
Hope that helps
Jon
Jon Sutcliffe / Solid Mastermind
The Solid Edge Community. Video training sessions, best practice documents, process maps and interactive training http://www.SolidMastermind.com
They do a free trial though so could be worth signing up for that.
I've been running a trial version for a few weeks.
The only problem I've found is that it seems to struggle with assemblies of even a few hundred parts.
If you notice, the demo's on the web site are fairly simple models so I suspect you would have to restrict the number of parts to just those that are absolutely necessary.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
