Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I think the forum is a great idea, especially for those of us in consulting engineering. Keep up the good work!..."
Geography
akcrusier (Computer)
14 Apr 10 16:21
I have a sheet of rohacell pmi foam sandwiched between two sheets of carbon fiber that I need to cut. My first thought was to use a waterjet but I am worried that the material might delaminate. Does anyone have experience cutting a material like this?
Compositepro (Chemical)
14 Apr 10 19:12
An abrasive waterjet should work if the sandwich is not too thick. But a diamond blade saw would be a lot cheaper and would also work unless you have curved cuts.
rstupplebeen (Mechanical)
15 Apr 10 8:47
If you need to make an intricate cut by hand I have used standard band saw blades with the work piece resting on a pedestal.  I hope this helps.
Rob Stupplebeen
materialsliz (Aerospace)
15 Apr 10 16:03
We make similar panels and use diamond saw predominantly for straight cuts.
allcomposites (Materials)
26 Apr 10 13:19
The best is to use high speed diamond saw and cut slowly otherwise it delaminates. I do not recommend water jet unless you have a proper injector (it is very easy to delaminate with common water jets).
MSSandvik (Materials)
24 May 10 11:11
Diamond 'encrusted' (brazed diamond) stuff works the best for me to prevent de-lamination/de-bonding.
If CNC-ing you can get endmill/router versions.  accuracy is not the best though.
Close Box
Join Eng-Tips® Today!
Join Us             Close
