Welded Pipe Patches
Welded Pipe Patches
We receive "requests for temporary approval" from various ships who weld pipe patches on various piping systems with through-wall leaks. We disposition each request on a case by case basis. We do not know of any industry standard for pipe patch geometry, weld joint design (I am referring to simple lap patch), or special NDT requirements. Does anyone know if such a standard exists? We would like to provide the fleet with some info on how to properly affix such welded patches before they come to us with requests to approve patches that are too small, incorrect geometry, improperly NDT'd, etc.
RE: Welded Pipe Patches
The link below is for the Pressure Vessel and Piping Design Forum at the ASME site. These are the people who have standards for this kind of repair. I suggest that to place your question there.
Don
dleffingwell@snet.net
http://www.asme.org/bboard/main-frame.tcl?topic=Pressure%20Vessel%20and%20Piping
This method allowed some "standard" work processes with people not capable of code certification, but still had the engineer in the loop. We only did these standards where we had a large amount of repeat usage.
I wonder if you could not use such an internal standard to streamline your work process while maintaining the oversite necessary to assure any thing out of the ordinary did not escape engineering oversite.
When doing such repair designs in the past I have relied on ASME Section VIII Div. I and Div. II. The API standards allow you to evoke Div. II rules. This allows more flexibility and experience judgement in the design by the engineer. All this leads in my experience to more options not less and thus less specifics not more.
Note that Plidco has some clamps available for quick fix. The thing u really wanted to do is to ensure u have enough meat on your exisitng pipeline before doing the weld - should not be less than 5 mm minimum to prevent burnthrough.
The other reference u may want to consider is the AWS Welding Tech Sereis "Pipeline Welding and Inspection"
Thanks for posting,
Nelson
