How to select the faces of a feature
Hi together
I like to select all faces of a feature (like a hole pattern) to give all of them a name (Edit --> Properties) without selecting each single face. I didn't found a way to do this. Is this impossible?
Thanks for your feedback
RE: How to select the faces of a feature
NX7.5 appears to have some inhancements that may help you, including picking instances (and not single faces) in syncronous modeling.
It is annoying, that in this function "Properties" the selection Dialog is limited to this simple "Class Selection" Dialog. In other functions, NX6 allows the selection of feature faces.
Yes, I agree that there should have been some option to define criteria (by user) in the Class selection dialog. Criterias can be
All faces (edges) having some diameter (>=, <=, == )
All blend faces having same (range of values) blend value. and so on.
