FLAT PATTERN EXTENDS DIMENSIONS IN PARTS LIST
How do you read the flat pattern extend variables:
<FLAT PATTERN EXTENTS WIDTH> & <FLAT PATTERN EXTENTS LENGTH>
into a field in IProperties so it will appear on the parts list in a drawing?
Pieter
Pieter
RE: FLAT PATTERN EXTENDS DIMENSIONS IN PARTS LIST
In Parameters section SHEET METAL PROPERTIES -> ENABLE Thickness parameter (tick it) and create Flat Pattern First
Then paste the following in parts list field:
=<Thickness> - <Sheet Metal Width> x <Sheet Metal Length>
Hope it helps some one.
Pieter
