2 Holes in (blind?) Flange
I need to have two holes in a 11in blind flange. Could weld in two pipe nipples in holes of an appropriate diameter. Is there a better solution? Would like to have 2 or 2.5 in pipes.
Welska
Welska
RE: 2 Holes in (blind?) Flange
Is this a piping question? forum378: Pipelines, Piping and Fluid Mechanics engineering
'Cause I'll just bet it isn't a software related question!
Are you an engineer? What is your background in evaluating and designing blind flanges? What codes or standards are involved? What jurisdiction will the blind be installed in? Are you serious about the 11" diameter? Are you serious about the 2.5" pipe? Might these be made of steel or are they fabricated from cardboard? What pressures are involved? What fluids are involved? At what temperature? Where will the holes be located?
Sheesh.
jt
