Set point of the minimum flow by-pass valve
We have pump datasheet from the vendor that shows the minimum flow (MCSF)is 21m3/hr, while on the pump vendor IOM manual the set point of the minimum flow for the by-pass valve controller is 34m3/hr, which is 40% of the pump rated flow.
My question is: how to determine the set-point for this type of by-pass valve? Shall we use the MCSF on the data sheet or shall we request pump vendor to determine?
RE: Set point of the minimum flow by-pass valve
"The problem isn't finding the solution, its trying to get to the real question." BigInch
http://virtualpipeline.spaces.live.com/
Ash Fenn
www.cdrpumps.co.uk
Reza
