Sync/Async generator efficiency
Good morning everybody.
I am responsible for evaluating heat loads inside the nacelle of a small wind turbine (100kW).
That´s difficult to find catalogs which describe the mechanical efficiency for generators. These data are almostly available just for motors, either synchronous and asynchronous. And I know it is a wrong thing to use the same efficiency coefficients for motors.
I don´t need very refinated estimatives, rough ones are enoough for our conservative calculations.
Does somebody have information about mechanical-electrical conversion efficiency in this range?
Thanks for attention.
RE: Sync/Async generator efficiency
Use motor efficiencies. Most of the heat developing sources are the same. windage, winding losses I2R, hysteresis, etc.
Any difference will be much less difference than day and night or a small breeze.
Bill
"Why not the best?"
Jimmy Carter
Right.
That rough efficiency estimate is enough for my thermal load calculations. I have found few efficiency data and now I can deal with both generator and motor efficiency.
Thanks.
Dad, are there cakes, pies and panettones in Brazil?
Pay attention, son: if there are not such things, we will make them ourselves.
(Carlo Bauducco, about to emmigrate from Italy)
Thinking better, I have found efficiencies in the 94-95% range for high efficiency asynchronous motors, while the async generators have shown up to 92% in the few catalogs I have found.
That means some kW of difference.
I found a catalog of Metalcorte (former Eberle) with open circuit and blocked rotor tests. I think I can reach async generator efficiencies from that.
But, thanks even so.
