Measuring Surface Infiltration/Runoff?
Does anyone have any experience trying to estimate surface infiltration? Ultimately, I would like to be able to look at the infiltration rate and relate that number to runoff, but wanted to see what luck people have had doing this?
The main problem that I think I will run into is preventing the water from escaping out the sides of the infiltration test area since it may be difficult to get a good seal.
Any advice/suggestions?
RE: Measuring Surface Infiltration/Runoff?
Civil Development Group, LLC
Los Angeles Civil Engineering specializing in Hillside Grading
http://www.civildevelopmentgroup.com
http://www.civildevelopmentgroup.com/blog
I will post back with what we find out.
2) As CGV writes, compaction kills percolation. (Also as times goes on, fines will collect in the gravel and start to plug the underlaying soil.)
3) Consider adjusting your initial abstraction volume (inches of rainfall) based upon your gravel depth + your underlaying soil. While 4" of gravel & 20" of gravel, both present a gravel surface for your CN, the initial abstraction is very different.
4) You may adjust you underlaying soil CN based upon available soil storage above the seasonal high ground water. There is a correlation between depth to the SHGW and soil type. You can always get a NRCS soil technician to verify the on-site soils.
5) Infiltration rate is not directly related to soils type. We have many B/D soils with nice, >6"/hr DRI percolation rates but when the water table rises or mounding occurs, the percolation rate is dramatically reduced. I recently had a project with a 12"/hour DRI percolation test and a <0.12"/hr infiltration rate when groundwater mounding occurs.
6) Consider modeling the gravel as a shallow pond. Run a groundwater mounding analysis to see how it will percolate.
http
Streets and roads:
A B C D
Paved; curbs and storm drains (excluding right-of-way)
98 98 98 98
Paved; open ditches (including right-of-way)
83 89 92 93
Gravel (including right-of-way)
76 85 89 91
Dirt (including right-of-way)
72 82 87 89
Clifford H Laubstein
FL PE 58662
Since you appear to be working with TR-55, Mr. Laubstein's approach of adjusting the initial abstraction in your model to account for the voids is probably the cleanest, and easiest to justify to other engineers or reviewers. To some degree, it was put in the model to handle just such a situation.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
