oring groove size
oring groove size
Using the standard Parker Oring design catalog (yes, I still use one) It tell you everthing, piston size, groove dimensions, etc for a std 9.000 bore. I am slightly non-standard. 9.125 bore. How can I re-size all the values and still hold a vacuum?
Any help would be appreaciated.
RE: oring groove size
http://www
and more. .
Still have issuses with oring groove size.
The 9.125 bore is fixed. I can make the plug and groove diameter anything that holds a vac seal. I also would like to use a standard oring. Maybe a 446?
I have used the on-line calculator but the values do not make any sence.
Any ideas? I really hope not to use a custom oring.
Aay help would be greatly appreciated.
Lost in the groove.
You saved me. Thanks for your advice and help. I used the Parker calculator and obtained the info.
Thanks again.
