Graphic problem! Computer is going to DIE
Ever since I start using this new work station at work all pop-up window inside catia appear in the middle of the screen. It's quite a pain in the backside because I ether have to work around them or move the pop-up window with every function. Does anyone know how to stop this? I'm running an ATI Firegl V7200 with the most recent driver 8.583.0.0. Windows XP pro
This is a huge pain... please help!!!
Dean
RE: Graphic problem! Computer is going to DIE
using xp pro sp3
or u just have a card that might not work that good with catia, also check openGL settings might make a difference
regards
It was a setting on ATI's hydravision parameters. It has a box called "dialog control" that I had to uncheck it.
thanks for the input.
Dean
