Convection htc for air
I'm sure this has been covered in a million other threads but I'm looking for some typical values for the heat tranfer co-efficient for air.
1) In the case of indoor air at ambient temp with little circulation.
2)  Outdoor process unit exposed to wind and so on.
James
RE: Convection htc for air
You can take a glance at the link below for some background theory
http://www.cheresources.com/convection.shtml
Or give a shot to this calculator (I find it quite useful)
 http://www.thermal-wizard.com/tmwiz/default.htm
Air properties (to be evaluated at film temperature) are tabulated in the thermal-wizard site, anyway if you have to deal with values not reported there, you can try this site:
http://www.mhtl.uwaterloo.ca/old/onlinetools/airprop/airprop.html
For 1) take 10 W/sqm degC. For 2) the value will depend on wind speed. 20 W/sqm degC is easily attained with moderate non stormy winds.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
Thanks for the info, very usefull.  I really should have paid more attention in fluid mechanics!
