C.S ASTM 106 Gr-B for 20%HCL
Hello
could you please provide comments on if C.S ASTM A-106 Gr-B be used for 20%HCL??? we are using same material for fresh/spent H2S04 as per bechtel piping specs recommendation. I found through bechtel piping specs that for HCL, Glass reinforced FRP Epoxy resin and CPVC are recommended. Though these are also recommended for H2SO4 as well. can you comments for all these materials for HCL service.
reply sooner
Norm
reply sooner
Norm
RE: C.S ASTM 106 Gr-B for 20%HCL
You can find corrosion data for carbon steel and other material here:
http
this paper from NIDI is a guidelines to select material in HCl service.
http://
corrosion resistance data
hope this can help u
Vitt
Corrosion & Rust Prevention Control
