VFD with small synchronous AC motor
I need to run a small 120VAC/60Hz/72rpm single phase synchronous motor at one third or one quarter of its nominal speed. The obvious solution that comes to my mind is using a 220 VAC VFD (one of its output phases and neutral) to run the motor, and adjust output voltage and frequency accordingly, lets say, to 40 VAC at 20 Hz. I don´t have much choices, since I can't change gearing and cannot get a slower motor. My question is, can I do it with no ill-effects other than reduced torque?
The motor is a slo-syn SS241-1003 that is part of a Honeywell Herculine series actuator. The motor is located in a tricky location, so my main concern is not damaging the motor. Thanks for your comments.
RE: VFD with small synchronous AC motor
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Slo-Syn motors are stepper motors and not at all like standard induction motors. There are special drives to use with them.
They are probably discontinued, but occasionally available on eBay. Or produced by someone else than the original manufacturer.
How was it run before? Isn't it possible to sdjust the frequency setpoint of existing drive?
Gunnar Englund
www.gke.org
Change your motor for the model SS-242.
The Bronco controller from Seco is specifically recommended to drive the SS-242
http
If you prefer a mechanical solution, gear boxes are available for the SS-241.
These are available with a range of gearboxes including 3:1, 4:1, 5:1, 9:1.
htt
Page 20.
Yahoooo
Bill
"Why not the best?"
Jimmy Carter
What I need right now is to test the concept of slowing down the motor to see if it helps with a particular process problem we are dealing with related to the actuator´s speed. If it works and an optimum speed is determined, then I'll try too find a suitable slower motor to run the actuators or even change the actuators altogether.
In the meantime, I'll check my available VFDs (Powerflex 4s and Saftronics GP10s is what I use) to see if they can handle unbalanced loads (anybody out there knows beforehand?), and use a transformer to step down and isolate the output voltage. Now, assuming the test works out fine, do you think it will be OK to leave the VFD running the motor for a few weeks or months while we change the motors? My concern would be if those types of motors "like" the switched/reduced voltage from a VFD, although I guess the output transformer should somewhat smooth out the switched output voltage. The duty cycle of the motor is about 5 seconds CW, 5 seconds CCW, 5 seconds OFF, 24/7. The actuator is in a very tricky and hot place, and it is not nice to change it in the night shift for example :), that's why I´m concerned about reliabilty.
Thanks again in advance for your comments.
(So, they are not stepper motors? They usually are)
Gunnar Englund
www.gke.org
JRAEF, I saw one of your posts in a similar disussion where you mention that none of the current line of AB 3-phase drives can run a single phase motor. There is no way then to switch off the phase unbalance protection on those drives? If that is the case I'll try first a Saftronics GP10 drive, is it possible on those? Have't measured it but motor current draw should be pretty small, so maybe I could get away with it?
Now I am also concerned about Skogs comment, since cap reactance at 20 Hz will be 3 times higher I don't what it will affect most, starting or running torque (or non of the above hopefully?)
If I really need to change the cap to make the intended test it complicates things quite a bit, because then I'd have to take out the actuator and change the cap, if I only add the VFD I can do it all externally and pretty easily with minimal process disruption.
thanks again guys
The manufacturer describes this as a three phase motor.
The RC network is added to run it on single phase.
This motor only uses two windings on three phase.
The currents will be unbalanced.
The manufacturer builds suitable gear boxes.
You should disconnect the capacitor for three phase operation, either by VFD or across the line.
Mistakenly describing a three phase motor as a single phase motor and then trying to solve the problems of running a single phase motor on a three phase source can be confusing.
220763-004 may be a suitable reduction gear.
CLICK the LINKS.
RTFM
Bill
"Why not the best?"
Jimmy Carter
Also, for 3-phase operation I would have to remove the actuator from the process to access and remove the capacitor, which is something I definitely need to avoid at this stage.
So, back to the question, do you think it will be OK to run it as it is at 20Hz, assuming the VFD doesn't trip for unbalanced load. What would the actual effect on motor performance if I don't change the cap?
Thanks again everyone.
For an example see the FFP interface board from Advanced Control Tech:
http
Good Luck,
Sean
Even if you do find a suitable 1-phase VFD, that RC phase shifting circuit will most likely just cause you trouble.
So, remove the RC circuit and run the motor on 3-phase. It should not be hard to find a transformer or even 3 x 1-phase transformers wired correctly.
If we forget the 'interesting' use of Floating Point, how would that device work with an induction motor?
Gunnar Englund
www.gke.org
The motor is capable of being stalled so the duty cycle should not be a problem.
There is a VFD recommended for the 230 Volt version of this motor. If you go with a VFD how about buying the proper VFD and using 480:240V transformers at 50% voltage to drop the VFD output down to 120v. The transformers should isolate the motor from the voltage spikes, but if the 120V model is wound with the same insulation as the 240V model, PWM should not be a problem.
To anyone interested, this is not a stepper motor. This is a three phase synchronous motor using multiple permanent magnets in the rotor. The fields run on 60Hz AC. The motor uses an RC network to create a phase shift for single phase applications. Sort of a miniature rotary phase converter.
Bill
"Why not the best?"
Jimmy Carter
Waross, about your suggestion of varying duty cycle as an alternative, I discarded initially because I'm actually monitoring actuator position via slidewire feedback and need the movement to be pretty smooth rather than step like, but what if I go to the extreme of switching maybe 3 cycles out of 12, for example, to achieve a smoother movement. Do you think I would get more torque at low speed that way than with a VFD? Right now I´m concerned that maybe I won´t get enough torque with the VFD solution, so I may need alternatives.
The torque should be good with a VFD.
The Bronco VFD is recommended for this motor. With a two winding, three phase motor, unbalance will be inherent. The safe way is to go with the recommended VFD. If you have a VFD on hand, try it and see. Feeding a small delta/delta transformer may help with the balance, isolate the motor somewhat from the PWM pulses and get you 120V from a 240V VFD.
There is a gearbox option if your actuator has room for the extra length.
Duty cycle at 3:12, try it and let us know.
Bill
"Why not the best?"
Jimmy Carter
Rating 2 amp maximum resistive @ 24V
Electrical Life 100,000 operations
Two amps resistive at 24 V. Nothing said about inductive load and higher voltage. Not to mention the 'bumpy ride' that kind of control will produce. Also, the switching will probably not be synchronized with the grid cycles. No way I would try such a thing.
If the device is to be used to reduce number of cycles from 60 to 20 per second, it will switch on/off 20 times per second. That is rather tough. And life at 24 V resistive will be around a little more than 1 hour. If not loaded at all (mechanical life is 1 million cycles) it will be just under 14 hours.
Isn't this thread getting rather impractical? The main reason for all this seems to be a problem to get acess to the motor and its terminals. How difficult is it anyhow? Most machines I see need a few covers to be removed - at most. Are these covers welded in place?
Gunnar Englund
www.gke.org
But I agree with you.
There are both VFDs specifically approved for this motor and gear reduction options available for a mechanical solution.
"Fix the motor without touching the motor" is becoming tedious.
Bill
"Why not the best?"
Jimmy Carter
I had a proprietary analog computer that wasn't doing its job. I suspect that it never did it's job. Actually, times four, there were four identical lines.
The computer controlled motor operated valves. The valve position was fed back to the computer. The actuator motors may have been similar to yours but memory fails.
We dumped the computers and went with a pair of economy model PID controllers. The PID controllers had no trouble monitoring the process and outputting control signals but the problem was interfacing with the existing valves.
I put the PID controllers on time proportional control. I set the on-time to open the valves about 5% or 10%. When we were below setpoint, each pulse would progressively open the valve. Eventually the valve would be 100% open. When the PV went a few percent above set point, an alarm contact would drive the valve to the off position. When the PV dropped, the PID would slowly start nudging the valve open. The system was more stable than it sounds. There was a long response time to the process and the valve would hang in a close to optimum position for quite awhile. Then it would eventually go above set point and be driven closed. It would then start opening by increments and again hang at close to optimum position for awhile.
You may be able to do something similar and not open the valve all the way and so slow the cycling down and get closer control at the same time.
To the control gurus;
If I came across such a system without knowing the story behind it, my scornful reaction would be about the same as yours but here's the back story.
I intended to install control valves that were compatible with the PID controllers.
With the new system the batch time which had been running over 28 days was reduced to 7 or 8 days. We thought we could get down to 4 or 5 days but the owner declined.We had more than enough throughput and a bottleneck had been eliminated. The owner did not want to take a chance on degrading product by pushing it too fast and we were producing enough product by far.
The new controls were so successful that a $50,000 plus expansion (on which the majority of the money had been spent) was canceled permanently.
The owner was offered %2000 each for the 4 old computers if he would trade them in on the new improved version computers. He declined to consider any more computer controls. (The new controls packages had probably cost about half that.)
I tried to buy proper control valves so I could use normal proportional control. The owner declined. We were getting all the good quality product that we needed. Why spend more money. The temporary kludge had worked well enough that it became permanent.
Bill
"Why not the best?"
Jimmy Carter
Without going into details about the process (which I can´t for confidentiality reasons), this is not a valve actually, we use the actuator to move slowly an electrode into "something" while monitoring its position, and as soon as we detect a certain condition we record the position and withdraw the electrode until another condition is detected, rest for a couple of seconds, and start again, about 4-5 times per minute. each cycle is basically CW movement for 5 seconds, CCW for 5 seconds, rest for 2 seconds... There are better ways to do this which we will eventually do, but in the meantime for test sake I need to be as un-obtrusive as possible, so please pardon my obstination with this seemingly trivial issue (wow, this sounds poetic)
again, any help will be greatly appreciated
Thanks a lot in advance for your final comments, any opinion or educated guess will be very welcome.
The interface I suggested basically varies the control signal duty cycle to slow down the motor movement. For example if applying the normal 120VAC control signal makes the motor move 90 degrees over 30 seconds, the interface would add "off" pulses to the signal such that the motor moves, pauses, moves, pauses, and so on. In this way the normal 30 second travel time can be changed to a longer period.
This interface is not applicable to any ordinary induction motor, only this specialized case where the end user supplies single-phase CW and CCW control signals to postion the motor.
Cokeguy-
Honeywell Herculine actuators are designed to have the control signals pulsed for precise position control, so it shouldn't hurt the motor. I think your suggested 100ms pulse widths is in the ballpark, just keep in mind if the pulses are too short then they won't move the motor.
We use Herculine's frequently in this manner to precisely position large air dampers for combustion applications, and they are some of the toughest electric actuator's we've found. We normally use PLC's to control them, and our program applies constant 120VAC power to move the actuator until it's close to the desired position, then pulses the control signal 500ms on and 1500ms off until we are within the deadband around the desired position.
Best of Luck,
Sean
For 20 Hz and 40 volts try adding 60 uF for a total of 67.5 uF
You want x 3 for 1/3 frequency, and another x 3 to maintain the current at 1/3 voltage.
According to the FM, the starting current is so close to the running current that short duty cycles should not be a problem. The unit will come up to speed in about 1 1/2 cycles.
Bill
"Why not the best?"
Jimmy Carter
So this is not a mode where you synchronize switching with periods? But rather switch the motor on and off?
That does work for setting position of a damper or a similar thing, but it doesn't reduce speed of the motor - it just makes the motor stop and then runn att full speed and so on.
Is that what the OP wanted? My take is that he wanted to reduce speed to one third and also that the motion should be smooth. If that is not necessary, the "macro" PWM technique will surely work. Done the same thing with Siemens (Landis&Gyr) actuators. But used triac output instead of relays. Relays wore out much too quickly.
Gunnar Englund
www.gke.org
Yes that is my understanding of the OP's application since he previously described the duty cycle as powering the motor CW for 5 seconds, CCW for 5 seconds, off for 5 seconds, and repeat.
I agree the motor while powered still moves at full speed, and that triacs are superior to relays for this type of switching.
Hopefully the OP will return and advise how it worked out.
These motors are rated to stop within 5 degrees. If you want less operations it may be easier to introduce a time delay at the top of the stroke.
Bill
"Why not the best?"
Jimmy Carter
