SY50 Scotch Yoke Gear Operator
I'm having a hard time finding any information on this operator.  I need to know mounting information.  This is the little information I have:  I have information from a Grove catalogue (under Dresser), so I'm not sure if they manufacture the operator or just encourage buying them with the valve.
Does anyone have information on this?
RE: SY50 Scotch Yoke Gear Operator
The gear operator is most probably manufactured by Ledeen - Part of the Dresser family. Most Grove Valves are equipped with Ledeen operators. Grove/Ledeen/Dresser Flow Control division will be able to help. I am guessing you want maintenance info not operating instructions/methodology.
Why would you replace an inferior actuator with another?  I assume you actually want some repeatable control, low maintenance costs, and dependability?
Customers request.  I have found the information I needed, thanks for the help.
