Cant export from drafting to PDF....
I'm getting behavior on the UG side that gives the appearance of working... but the file isn't created.
Any ideas?
TIA
RE: Cant export from drafting to PDF....
What version of NX are you running?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
NX7... This problem is unique to my workstation. We have another it works fine on.
Then I can't help you.  I'd advise that you try GTAC.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Yes it is supposed to support exporting PDF files. I think you probably know that already. It makes sense to look at the obvious differences between the two workstations and how the software is installed on each. If necessary you may try re-installing, otherwise as John mentioned your options are to contact GTAC since the number of unknown variables is to numerous for us to help with.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
