Cylinder tilted / helical Pattern
I am trying to model a bonding pattern on an anvil roll. The pattern does not just repeat where a circular pattern creates the part. The pattern in in a helical pattern. I have modeled the part using Solid edge and the link is a screen shot of the part. The Part in edge is cumbersome to work with and very hard to edit. I am trying to see if Solidworks can create a part that is nicer to work on and edit. Any guides, clues, ideas, or help would be greatly appreciated. It has been a few years since I have done any real work in Solidworks and We only have 2007 for me to play on.
Thank You for your time.
RE: Cylinder tilted / helical Pattern
The best method would be to suppress the pattern when not working on those details. The same could be done in SE.
