Bolt Spacing + Gasket Joint Design
Hi All :
I am looking for reference/help in order to determine the bolt size and spacing required to design a gasket joint with 11psi pressure on a 0.5 in steel plate (with stiffeners) 126X133inch in dimensions.
Kapil,EWI
