One Way Mirror Surface Problem
Hello All-
I am modeling a part in SW2001+ and have an interesting problem. I have a boss extrude thin with some sketch derived cut extrudes through it. While doing some in assembly part editing, a "surface" showed up on my part. Here is the weird part. If I view the top of the part, this surface skin covers my cut extrude holes, and makes the part appear solid. If I rotate the part to the bottom side, I can now see through the cut extrude, and the part has the hole in it! It is acting like a one way mirror. If I view from the top side and select the "real" surface, the entire surface (including the mystery skin over the cut extrude) highlights, but if I select the "fake" surface (click within the cut extrude area) it will not highlight. Yes, I've tried rebuilding, shutting down and re-booting etc. Any ideas what this entity is and how to get rid of it aside from recreating my geometry?
RE: One Way Mirror Surface Problem
You could also just change your cut-extrude to cut a bit deeper (say .005 more) than what is it doing now.
"The attempt and not the deed confounds us."
