Cant create more than 1 exploded vew per Configuration
I am quite sure. But want to hear if its right.
I have an assembly and want to create 2 exploded views. I think its not possible to create more than 1 exploded view per configuration.
I think I need to create a Derived cfg to have the 2nd exploded view.
Any other possible ways?
BT
BT
~ BT
RE: Cant create more than 1 exploded vew per Configuration
Good work around. SW will allow this work around solution. But my documentation control dept might not, Because, we will need to check-in to vault, 2 assembly files for the same product.
Will try to check if they permit. Thanks.
~ BT
BTW I would WAY prefer using a derived config to create a second explode than creating an entire new assy. IMHO.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
