sight glass DN200 from CTP company
I have a cracked sight glass on one of the backwash waste lines in my sand filtration plant. I need a replacement. Our equipment specification lists it as:
CTP company product 360505
any idea which company this might be?
i cannot for the life of me find it online...
I am attaching a photo.
Best regards
rami
Best regards
rami
RE: sight glass DN200 from CTP company
Is that glass or plastic?
Steve
If you are discharging into a sump, you do not need the sight glass. In that case, install a pipe spool in place of the sight glass.
Best regards
rami
http://www.plastomatic.com/gyw.html
8" lexan (plexiglass) sight gauge.
6 and 8-inch Sched. 40 clear PVC pipe is available in the US. My Pittsburgh supplier stocks it. The photo seems to show a length of pipe with a Van Stone style flange (2-piece) glued on to each end. I have made many of these and some smaller. When fabricating, be careful not to get any glue or primer on the viewing surface. With the Van Stone flanges, hole alignment is not important.
Steve
