connecting motor and disconnect it when weight sensor reach it's max
Hi all
i want to make a controled cirquit for measure material. how should  i connect a motor that transport material and when materal weight reach 500 kg then  the cirquit need to disconnect.
Thanks in advance
RE: connecting motor and disconnect it when weight sensor reach it's max
Your best bet is to talk to a company that is doing this for their living. There is a lot more to it than just 'connect' a motor.
Gunnar Englund
www.gke.org
yes right, but i mean just a sipmle automated control with a weight sensor, and in the moment that reach max to disconnect  the motor that brings material.
this is my idea but ...
a scale with an nc contact wired into the motor starters control circuit. with a holding contact to prevent short cycling. seriously if you couldn't figure that out you need some experienced help
