Catia build and hot fix in file
I am doing a small foreigner job using Catia V5. As part of the deliverables it says the models to  be returned as Catia V5 r18 build 4 and hot fix 64.
I am able to do this on using on a spare works licence V5 r18 - but the build and hot fix is different.
Can anybody see this as an issue...I didn't think this info is recorded in the file is it?
RE: Catia build and hot fix in file
sorry..not the build no but the service pack is different
It is and will only be an issue if they try and migrate your data back into their PDM.  At that point they might/will refuse the data.  It will not be an issue if you are not sending data back.  If you open a part in wordpad you can see the version info.  R18 SP8 HF0
CNEXTINFOS-UpdateVersion-StreamBlock-SafeEarlyBlock-StrongEarly&V5R18SP8HF0 built on 02-06-2009
Derek
thanks..but it turns out I wont be doing this now anyway.
