eval and decimal numbers
Hi Matlab Folks
Let' s say: I have LS1=[ 0 0.2 0.4 0.6]
I want to have my variable names that I introduce in for loops looks like:
Variable_LS1_P0=Mat  % Mat are matrices calculated
Variable_LS1_P0.2=Mat
the command
eval(['Variable_LS1_P', num2str(LS1),'=Mat'])
does not work with Decimal LS1 values; there is any trick that I can make to make the eval function accepts decimal values.
Sherif
RE: eval and decimal numbers
two comments (based on my version of Matlab = 5.2)
1 - Variable_LS1_P0.2 is an illegal filename to begin with.  If I try to intialize the variable using...
Variable_LS1_P0.2=[1,2;3,4]
.....then I get error Missing operator, comma, or semi-colon.... pointing toward that period.
2 - My version does not concatentate strings using comma.  Need strcat function.  i.e. to create the string
I'd have to use
strcat('Variable_LS1_P',num2str(LS1),'=mat')
(although based on item 1, applying eval to this string would still result in an error)
Clarification in bold:
Quote (electricpete bold clarification):
2 - My version does not concatentate strings using comma.  Need strcat function.  i.e. to create the string Variable_LS1_P0.2=mat
I'd have to use
Constructing variable names (via 'eval') and then using them will almost always end in tears.  It will always end in a workspace polluted by large numbers of variables.
Search the cell array help.  A new-ish ML feature that makes DIY variable names a thing of the past.
- Steve
