finding the difference between graphite and impregnated graphite
I am holding a graphite part and I am trying to find out if it is impregnated or not. It is used for wear.
What should I look for?
Thank you.
RE: finding the difference between graphite and impregnated graphite
Have you seen it under SEM? You can see the graphite morphology clearly. On a similar note as a first attempt,you may look into several published literature on Al graphite composites. They are sure to have provided the treatments provided to the graphite ,interface structure etc.
