Writing bdf file
Writing bdf file
Writing bdf file
I've got a system model and want to write separate .bdf files of several different structures which will be stitched together later using "include" in the system bulk data file. Question, is there an easy way to write these separate structure files with several structures present in the .mod file?
RE: Writing bdf file
use the "active set" command when exporting your model.
be sure that everything you want including (nodes, co-ords, elements, constraints, loads, ...) is in the active set.
