ORDINATE DIMS IN A DETAIL
CAN SOMEONE TELL ME HOW TO PLACE A ORDINATE DIMENSION INTO A DETAIL VIEW WITH THE ORIGIN OUTSIDE OF THE DETAIL VIEW?
THANKS
REP
RE: ORDINATE DIMS IN A DETAIL
OOPS!
IV PRO 2010
REP
I am not sure about ordinate dimensions but for a standard dimension you can turn on some work features from your model. Next create a dimension to it and RMB -> dim type -> Linear Symmetric. Now turn off the work feature.
Haven't dried it with ordinate but you may be able to create it manually this way if it doesn't work.
Just use the "ordinate set" command and it should work just fine.
Select your origin, your features, then r-click, continue.
Hope this helps.
Sorry Sam, tried that but not sure how it would work.
REM: im trying "TO PLACE A ORDINATE DIMENSION INTO A DETAIL VIEW WITH THE ORIGIN OUTSIDE OF THE DETAIL VIEW"
Can you show me in a PDF?
REP
