Use of Tabular Dimensions
Hello all,
I am in the process of assisting in the update of David A. Madsens' 5th Edition of "Engineering Drawing and Design", published by Thomson-Delmar Learning. I am working on Chapter 25 which covers HVAC, Pattern Development and Precision Sheet Metal Drafting.
In the Precision Sheet Metal Drafting section, it is stated that for items such as chassis layouts, that the method of dimensioning these parts "...includes standard unidirectinal, arrowless or tabular dimensioning systems".
My question is this: Is tabular dimensioning used that much for this type of sheet metal work?
Thank you for your reply's.
RE: Use of Tabular Dimensions
Is there any reason it should not be?
No, I just wanted to verify that it is used in sheet metal dimensioning. Tabular dimensioning isn't a style of dimensioning that is seen that much. My thinking was that ordinate dimensioning would be used predominantly but tabular does seem to have it's purpose in sheet metal.
After nine years on SolidWorks, I finally used their tabular dimensioning. I recently had a plate with sixty threaded holes in it. Any dimensioning scheme other than tabular would have been unreadable. A complex, spline outline might be a candidate for tabular dimensions as per Fig.1.35 in ASME Y14.5-2009 (Fig.1.32 in ASME Y14.5M-1994).
Perhaps a better question to ask would be if anyone has an example of a justifiable tabular dimensioned drawing. It would illustrate the technique, and show off the problem it solves.
Tabular dimensioning is someting that sits in your toolbox until you need it.
Hole tables do get used some here.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
I would be careful with the word "often". In my case, once in nine years probably does not qualify. KENAT's mileage may be different. Actually, I managed to do tabular dimensions on AutoCAD_10 a very long time ago.
I claim that the dimensioning and tolerancing of low precision components is critical too, and in many cases, more complicated and challenging. What you really need to do is show your readers what options are available for applying dimensions to their parts.
