Piston vs Diaphram
Piston vs Diaphram
We are needeing to replace a 12.25" duplex piston / plunger pump with 4" inlet and discharge. The process in un-screened primary domestic waste sludge. Is this the right pump for the application? How will a diaphram pump compare to a plunger in this application? This is a high grit and solids process.
RE: Piston vs Diaphram
Steve
